What is this?
Old Jul 7, 2017 | 09:10 AM
OffroadFrance's Avatar
Originally Posted by KernowDiscovery
Hi Steve,
How difficult of a task was replacing the shuttle valve switch? Still have this on my 'to do' list.
thanks,
Christina
Hi Christina
I used this kit, it's a genuine Wabco part but already modified correctly. It's twice the standard part but half the hassle to fit and it works perfectly. I used this one on mine.
Landrover Discovery 2 Defender ABS Modulator Shuttle Valve Switch Repair Kit | eBay
It's child's play to fit .................. honest
Old Jul 7, 2017 | 09:16 AM
That is the ABS Sensor Connector.
X1 ........... IMO it's not absolutely necessary to hard wire the sensors as they rarely cause problems as standard plug in's.
Old Jul 7, 2017 | 12:33 PM
mln01's Avatar
Originally Posted by OffroadFrance
Hi Christina
So this is a new SVS set modified to include the Option B fix. Very clever. Maybe unnecessary but clever nonetheless.
It looks like its advantage is that it's plug and play, which can be valuable for those uncomfortable cutting wires, soldering and applying heat shrink. It should leave people happier than they would be if they installed standard, new SVSs only to have the Three Amigos remain because the modulator circuit board problem was not addressed.
Old Jul 7, 2017 | 02:23 PM
KernowDiscovery's Avatar
Hi Christina
Thanks Offroad! I may be able to attempt this myself. $100 isn't bad especially if it's plug and play and includes instructions.
Old Jul 7, 2017 | 02:32 PM
It's defo a plug and play kit. The instructions for fitting were included with mine. It takes an hour or two to fit properly and then no-more amigo's come visiting unless the wheel sensors go duff.
PS: everything is included in the kit so nothing to buy provided you have the tools.
Old Jul 7, 2017 | 02:42 PM
KingKoopa's Avatar
X2 when/if my front sensors ever go bad I will be splicing in the OE style connector to make future changes easier.
Pretty sure LR switched to the updated sensor wire because they thought the connectors were the source for the faults. Turns out they were wrong and the connectors are fine, the fault was ****ty sensors.
Old Jul 7, 2017 | 02:43 PM
I think I can muster up the tools if I can get to my workbench Need to finish my never ending projects in the garage - you know me! I'm going to try this.. thanks again for posting!
Old Jul 7, 2017 | 02:49 PM
There are a batch of wheel sensors around that are too long and 'collide' with the reluctor plate but LR would never admit to that
TIP: before fitting a new wheel sensor dimensionally check it with a good vernier gauge first.
Old Jul 7, 2017 | 03:38 PM
KingKoopa's Avatar
I did not know that... interesting.
The sensor I just installed the other day was $18 on ebay and is working well so I will probably go the route in the future. In fact I may just order 4 of them for future use.
