What is this?
Old Jun 9, 2019 | 08:45 PM
Dherna's Avatar
Default What is this?
Flushing the cooling system and changing the tstat and saw this just hanging loose. What is it?
Old Jun 9, 2019 | 08:52 PM
FlyingZebra34's Avatar
The plug for the temp sensor on the bottom of the radiator? Passenger side bottom facing the firewall.
Old Jun 10, 2019 | 02:51 AM
JUKE179r's Avatar
Thoroughly check that URO brand hose for wear and deformation from expansion! I've had a few friends have their newly installed URO coolant hoses burst on their Disco 2 and BMW E60.
Could've been the hose or could've been the 2 different mechanics who installed it.
Old Jun 10, 2019 | 10:58 AM
Dherna's Avatar
Thanks for the feedback guys... I guess I better plug in the Temp Sensor to the radiator!!!!! I've checked the hoses and changed all the clamps, so far they are still in good shape.
Old Jun 10, 2019 | 11:43 AM
Best4x4's Avatar
With that unplugged you’ll usually get a P0126 fault.
Old Jun 10, 2019 | 11:50 AM
mollusc's Avatar
i don't think all trucks have a sensor in that area. my '99 doesn't seem to have one -- only the sensor up behind the alternator.
Old Jun 10, 2019 | 11:56 AM
Motorhead1's Avatar
I think it may only be on S.A.I. engines, which is more common. idk know for sure though...
Old Jun 10, 2019 | 11:57 AM
Dherna's Avatar
I'll check this evening to see if I have the sensor... if not, it just hangs there? would some radiators have the sensor option?
Old Jun 10, 2019 | 12:41 PM
Best4x4's Avatar
SAI = additional temp sensor on the radiator. Non SAI = no additional temp sensor. I’ve worked on plenty of D2’s where they have the opposite setup for their needs due to a previous owner or getting a used part from the wrong model vs how their D2 is equipped. Also a lot of new radiators have the hole but you either leave it plugged or install the temp sensor.
Old Jun 10, 2019 | 08:15 PM
Dherna's Avatar
So looks like SAI... right?
SAI right? But don’t see a temp sensor on the radiator.
