What are acceptable long term fuel trim numbers?
Old Apr 1, 2019 | 08:32 PM
Ben Matheson's Avatar
Default What are acceptable long term fuel trim numbers?
Did a search but nothing indicated a normal range
Old Apr 2, 2019 | 02:20 PM
Billfromthehill's Avatar
I believe anything over +10 or lower then -10 will throw a CEL if driven long enough. Below + or - 5 is good. Balanced trims for the opposing banks is important as well
Old Apr 2, 2019 | 05:40 PM
Extinct's Avatar
Agree with Bill, what are you seeing? If you have long term trims drastically different something has changed.
Old Apr 2, 2019 | 05:46 PM
Jeff Blake's Avatar
Yeah, +/- 5% is good. Mine is +1.5 on Bank 1, and 2.5 on Bank 2. Fluctuates a little bit from there.
Old Apr 2, 2019 | 05:51 PM
I was at -7 and -9. Just had exhaust flange gaskets replaced and was down to 5 and 7 after 1 short drive from the shop to home. I suspect they will continue to improve as I drive it more.
Old Apr 2, 2019 | 05:52 PM
Jeff Blake's Avatar
If you have a scan tool capable of resetting the adaptive settings, give that a go. Otherwise, keep driving for awhile and it should correct itself out (if you fixed the problem)
Clay Stanley
Dec 2, 2017 05:22 PM
aemnky606
Oct 25, 2017 03:20 PM
geek_IM
Jul 10, 2014 02:43 PM
Soul97
Feb 16, 2014 07:20 AM
Bamberson
Mar 30, 2012 09:05 AM
