Fuel trim
Old Mar 29, 2012 | 02:46 PM
Bamberson's Avatar
Default Fuel trim
Does anyone know about reading fuel trims and what they mean?
Short term bank 1, long bank 1&2 are running about +18%
Short term bank 2 is running at about +3%
Does anyone know what could be causing this?
These readings were at idle if that means anything.
Old Mar 29, 2012 | 08:53 PM
I have no idea what the normal trim level is so i cant say if yours is right or wrong.
Old Mar 30, 2012 | 08:49 AM
Do you have the exact fault code numbers?
Old Mar 30, 2012 | 09:05 AM
Bamberson's Avatar
No fault codes a popping up right now besides the p1171 and p1174. When I can afford it a new MAF will be going in.
If it means anything the banks level out to 0.00 (+/- a few) when I push to 2000 rpms. My o2 sensor voltage for bank 1 and 2 upper are around .7 and .8 while post cat are around .45
The reading on the MAF at idle is around 3.6 g/s I believe. Long term trim on both banks is around 22%
xhevi
Jan 17, 2019 01:31 PM
robson
Feb 22, 2018 05:42 PM
geek_IM
Jul 10, 2014 02:43 PM
Boxer12
May 9, 2011 06:17 AM
JumPeR04
Apr 7, 2011 09:52 PM
