What am I asking a machine shop to do with the heads?
Old Jan 24, 2022 | 01:59 PM
Brandon318's Avatar
Default What am I asking a machine shop to do with the heads?
Just check for flatness and clean them up?
Old Jan 24, 2022 | 02:16 PM
Extinct's Avatar
Clean up surface cut removing minimum material to get them flat. You can check yourself if you have a good straightedge. Should not be able to get a .003 feeler gauge under the straightedge anywhere.
Old Jan 24, 2022 | 02:26 PM
Richard Gallant's Avatar
@Brandon318 We call it truing around here, which is making sure the head in perfectly flat. Unless you heads are badly warped there is minimal material removed, often it is almost just a "polish"
Old Jan 24, 2022 | 03:01 PM
Alex_M's Avatar
A valve job is also never a bad idea while the heads are off.
Old Jan 24, 2022 | 03:51 PM
Brandon318's Avatar
Awesome! Dropped them off just now. $390 for cleaning, pressure testing, and potential resurfacing. They're the best machine shop in town. The guy came out to see what I had, and only seeing a small corner of them (they were wrapped in bubble wrap) he was like... "ah, Land Rover? Did it blow a head gasket??" haha, he knew right away.
Brandon318's Avatar
They're going to pressure test it first to see if it's needed, but yeah, I'm able and willing if it's needed.
Old Jan 24, 2022 | 05:17 PM
mln01's Avatar
Check out the "Cylinder head - overhaul" section of the RAVE workshop manual. There's more than enough info there about the heads and valves. You should definitely have the valves and valve seats inspected and ground/lapped as needed, and the valve guide seals should be replaced. The gasket set you bought should have included the valve guide seals.
You can also review the relevant sections of the 4.0 & 4.6 Litre V8 Engine Overhaul Manual linked below. Again, more than enough info to satisfy you, I expect.
4.0 & 4.6 Litre V8 Engine Overhaul Manual - 4th Edition - Land ...
Old Jan 24, 2022 | 05:23 PM
Extinct's Avatar
Holy crap, my machine shop charges $80 for the clean and machine.
Old Jan 24, 2022 | 05:36 PM
Brandon318's Avatar
Probably would’ve been cheaper for me to ship them there haha
Old Jan 24, 2022 | 07:03 PM
It was 250 (cdn) here and that included replacing the valve seals and checking the valves
