What is that bolt on the bottom of the front cover near the oil filter housing?
I noticed a few drops on the driveway and got underneath to take a look. I observed that the large 22 mm bolt on the bottom of the front cover just to the side of the oil filter was coated in oil. I cleaned it up and after a few minutes oil was slowly coating the bolt again. Can't get the best view of the rest of the motor due to that plastic shield/cover in the way. I started to loosen it to see if there was an oring in there that needed to be replaced, but it started to leak a bit of oil so I tightened it back up. I cleaned up the plastic cover that allows oil to leak everywhere but from the source. Why that was put in there is beyond me.
This is my first Rover and I have only had it for about a week. I have looked in the rave but nothing is mentioned about what that bolt is or what it is supposed to do. I know it is close to the oil pump. Can anyone shed some light on this rather simple topic? On my next oil change would I be safe in removing it? Will it cause any issues with the oil pump?
Thanks for any input!
Mecevans
08-09-2015 02:30 PM
texdisco
07-06-2015 08:34 PM
rvrguy
06-15-2008 07:19 PM
