What brake pads for stock D2?
Old Feb 13, 2010 | 11:11 PM
Rover_Hokie's Avatar
Default What brake pads for stock D2?
When I bought my D2 @ 80K is was just serviced at the stealership with new pads all around. My break light came on recently @ 118K and I checked the fluid and had to add a small can of brake fluid to top it off. (Thanks DiscoMike diagnostic info). Now I know this means it is time for new pads, so what do you guys recommend for brake pads on a D2 that will give me good brakes and not be so hard as to eat up the rotors? Just go with LR pads or is there something that will work better for me? I have just taken my stock D2 off road for the first time and plan to only do some light offroading in the future, standard tires and no lift planned for now.
THANKS
Old Feb 14, 2010 | 12:23 AM
Willie00d2's Avatar
The stock pads from the dealership work good. They do put out alot of dust though.
Willie
Old Feb 14, 2010 | 12:15 PM
Go to Atlantic British and look at what they offer. Their mid-grade and higher pads are good, better then factory pads with less dust and they can last longer.
Before you order any, pull a wheel and see exactly how much is left on the old pads.
Old Feb 15, 2010 | 03:16 PM
hilltoppersx's Avatar
+1 mike, check AB and check your old pads first
LandRoverChic
Nov 11, 2014 04:54 AM
DiscoSux
Nov 17, 2010 09:46 PM
Florida04RR
Mar 10, 2010 06:09 AM
ljdiscovery
Jan 17, 2009 01:35 PM
Tommy2tone
Sep 8, 2005 02:10 PM
