What is this called?
Not sure what the part name is but I believe that's the CDL positive engagement switch. OR it's the high/low positive engagement switch. The transfercase has two switches on it to let the computer know if the t-case is in high or low range and another switch to let itknow that the Center Differential Lock in engaged. That should clue you in enough to find what you need. Just find those two switches online and see which one looks like it.
on
I believe you are right after a closer review of the Rave Manual.
1.
SHIFTLOCK SOLENOID/NEUTRAL SWITCH
Service repair no - 41.10.63/64
This is sited on top of the transfer gearbox. Access to
the component is gained through the transmission
tunnel aperture.
Remove
tunnel aperture.
Remove
1.
Disconnect battery negative lead.
2.
Remove centre console. See CHASSIS AND
BODY, Repair, Centre Console
3.
3.
Remove rear passenger heater air ducts.
4.
Remove insulation pad.
5.
Remove four screws and remove main gear
lever assembly.
6.
Drill out rivets and remove tunnel blanking plate.
7.
Disconnect solenoid multiplug.
8.
Remove four retaining bolts and remove shiftlock
solenoid cover.
9.
Remove solenoid and spring washer.
10.
Clean joint sealant from mating faces.
7. Electrical connections
1.switch partially in
2.shows the cdl shifter, I already changed that switch, it works fine.
3. the third picture is the fuel pump
4. close-up of threaded hole for switch in question (Nuetral Switch)
5 is duplicate of 1, a slightly closer view.
KEY
1. Gearlever
2. Transmission tunnel aperture
3. Transfer gearbox
4. Bolt
5. Switch
6. Solenoid
1. Gearlever
3. Transfer gearbox
4. Bolt
5. Switch
6. Solenoid
It is not the solenoid, that is under the little cover with 4 screws.
This is my best guess....
http://www.roverparts.com/Parts/PRC2911.cfm
