What is this called?
Old Apr 6, 2010 | 04:22 PM
Danny Lee 97 Disco's Avatar
Default What is this called?
Gentlemen,
1997 Discovery I, what is this called? It is mounted on the right side of the transfer case right in front of the Solenoid Cover. Where is best place/price for new one?
All help appreciated.
Old Apr 6, 2010 | 04:26 PM
I can't get the picture to open.
Old Apr 6, 2010 | 04:32 PM
GARovee's Avatar
Not sure what the part name is but I believe that's the CDL positive engagement switch. OR it's the high/low positive engagement switch. The transfercase has two switches on it to let the computer know if the t-case is in high or low range and another switch to let itknow that the Center Differential Lock in engaged. That should clue you in enough to find what you need. Just find those two switches online and see which one looks like it.
Old Apr 6, 2010 | 05:53 PM
greg409's Avatar
That's your transfer case "neutral switch", I'm not certain what it does for you, though.
maybe turns on a light or chime?
luck,greg
Old Apr 6, 2010 | 06:12 PM
Default Nuetral Switch
I believe you are right after a closer review of the Rave Manual.
SHIFTLOCK SOLENOID/NEUTRAL SWITCH
Service repair no - 41.10.63/64
This is sited on top of the transfer gearbox. Access to
the component is gained through the transmission
tunnel aperture.
Remove
1.
Disconnect battery negative lead.
2.
Remove centre console. See CHASSIS AND
BODY, Repair, Centre Console
3.
Remove rear passenger heater air ducts.
4.
Remove insulation pad.
5.
Remove four screws and remove main gear
lever assembly.
6.
Drill out rivets and remove tunnel blanking plate.
7.
Disconnect solenoid multiplug.
8.
Remove four retaining bolts and remove shiftlock
solenoid cover.
9.
Remove solenoid and spring washer.
10.
Clean joint sealant from mating faces.
KEY
1. Gearlever
2. Transmission tunnel aperture
3. Transfer gearbox
4. Bolt
5. Switch
6. Solenoid
7. Electrical connections
1.switch partially in
2.shows the cdl shifter, I already changed that switch, it works fine.
3. the third picture is the fuel pump
4. close-up of threaded hole for switch in question (Nuetral Switch)
5 is duplicate of 1, a slightly closer view.
Attached Thumbnails What is this called?-partially-.jpg   What is this called?-dsc01617.jpg   What is this called?-dsc01614.jpg   What is this called?-dsc01618.jpg   What is this called?-dsc01620.jpg
Old Apr 6, 2010 | 07:05 PM
okdiscoguy's Avatar
It is not the solenoid, that is under the little cover with 4 screws.
This is my best guess....
http://www.roverparts.com/Parts/PRC2911.cfm
Old Apr 6, 2010 | 07:13 PM
GARovee's Avatar
Nuetral indicator switch would be the same thing as the high/low positive engagement switch.
Old Apr 7, 2010 | 03:01 PM
Anyone got an extra one laying around?
Old Apr 8, 2010 | 03:28 PM
Guys,
What is the function of the Neutral Switch?
What is the effect of running the vehicle with the switch screwed in but not connected (wires pulled out of old one)?
In other words, does it affect anything for it to be out of the circuit?
Old Apr 8, 2010 | 08:01 PM
GARovee's Avatar
Nothing as long as you can still shift the transmission and operate your HDC, TC, and high/low. The light on the dash just won't come on when the case is out of gear.
