What do you do each oil change?
Hey guys,
So I know there are a lot of generic lists out there, but I thought it might be helpful to put together a list of things you should do/check every oil change.
At the moment, I grease my drive shaft every oil change. I also check coolant levels.
What are some of the things you do every oil change?
I use Shell Rotella & change oil every 5000
> Grease Front & rear drive shafts
> Rotate tires front to back and back to front. Check tire pressure
> Clean/wash/Re-Oil K&N filter every other oil change.
> Inspect brake lines, rear air bags while tires are off. Also rock tires up/down, side-to-side to check for play, ball joints, tie rod ends. Check brake lights
> I check oil level and coolant every week...just because its a land rover. Usually before I go out wheeling
collin Barrows
08-28-2011 07:13 AM
onerovernut
08-15-2010 08:54 PM
