What do you guys think, 2000 DII with dropped sleeve
Old Jun 30, 2008 | 10:16 PM
ljdiscovery's Avatar
Default What do you guys think, 2000 DII with dropped sleeve
I came across a 2000 Discovery II, California Truck, looks like it has never been off-road. Radiator hose blew......long story short, cylinder sleeve dropped. roughly 110,000 miles,prior to the meltdown, everything was ingood working order, dealer maintained truck. I found three possible engine replacements, a 99 with 25k, a 2001 with 35k and a 2002 with 75k, all rolled. I am quoted around $1200 for any of the motors and about $1800 to $2000 for the removal and replacement of the engine. (front u-joints need to be replaced). What do you think? I figure another $1000 in incidentals, new plugs, wired, etc. What is the truck worth? Good body and interior, new tires, non-smoker, mint green exterior. Thanks Phil
'99 Discovery I 89k
Newly replaced Front Crank Seal, $110 parts and labor
Old Jun 30, 2008 | 10:25 PM
Default RE: What do you guys think, 2000 DII with dropped sleeve
Depends on how much they wont for the trk. If you can get it cheap enough go for it.
When the engine goes in my '97 I'll just have it rebuilt, same with the trans. So I dont think it would be a bad thing to buy it and then fix it.
Old Jun 30, 2008 | 10:35 PM
$1500 the way it sits....Phil
Old Jul 1, 2008 | 07:52 AM
Luv2Disco's Avatar
Personally, I would just find a truck that's running good and doesn't need the engine swapped. For not much more money than you'll end up investing you can find one driven by a soccer mom that's ready to go as it sits. Two many variables involved with the engine swap. I would only consider that if my own engine went out and even then, I'd probably just have it rebuilt by a trusted shop.
02 Disco II, 80K
Old Jul 1, 2008 | 08:11 AM
I would pass, the market is falling Disco's are getting so cheap, you would be better off looking around.
mattrickman
Jan 14, 2014 10:03 PM
msm15
Jan 18, 2011 09:54 PM
Erik
Jul 3, 2007 04:44 PM
sdanderson
May 14, 2007 10:59 AM
MRDM1
Mar 16, 2007 07:03 PM
