NOT AGAIN... Power Steering
Old Jun 30, 2008 | 06:03 PM
aBs0lut30's Avatar
Default NOT AGAIN... Power Steering
Well I am back again folks, this time with powersteering problems... I have had a bit of a leak for a while but it cleared up for the most part with a bottle of Lucas PS stop leak and some new hoses. but this weekend I noticed a large puddle of ps fluid under the car and on the way back from lunch the power started cutting in and out. Some times you get PAS sometimes is manual steering. Called the dealership and they want 1700 for the gearbox and 600 for the pump, so, I guess first question is how difficult is it to do the replacement? or can anyone offer any tips that could make it last another month? I got a really nice bonus check coming at the end of July...
Old Jun 30, 2008 | 06:28 PM
Default RE: NOT AGAIN... Power Steering
If you fill the p/s full of fluid, does it still act up?
I wouldn't just throwing parts at it without really having it checked out.
Old Jun 30, 2008 | 06:36 PM
aBs0lut30's Avatar
Well, when I first started having issues with it yes, it would quiet down after adding some fluid. Now, now mater what I do its still really loud.
Old Jun 30, 2008 | 07:10 PM
aBs0lut30's Avatar
Also, I just went out and played around a bit after the car cooled off a bit and what a puddle of fluid I had. Anyway, I started it up and its not making as much noise, but i noticed that the fluid in the res. is foaming a WHOLE LOT! does that mean anything to anyone?
Old Jun 30, 2008 | 08:46 PM
99LRDisc's Avatar
I dont know as much as the other guys. But my current problem, that i dont have the money to fix yet is a.. um.. seal? or gasket? somewhere, thats causing a leak and to loose power. This could be not related to you at all.. but just sharing my problems.
Old Jun 30, 2008 | 09:39 PM
What year is your trk? If it is a DII is takes power steering fluid, if it is a DI it takes ATF for poer steering fluid. If you use to much stop leak you will clog it.
I would flush the system and start with fresh fluid.
Old Jul 1, 2008 | 06:45 AM
aBs0lut30's Avatar
Its a 2001 so a Disco2, I only used one bottle of the stop leak and as much fluid as is comming out of this thing I dont see how there could be a clog...
Old Jul 1, 2008 | 08:12 AM
The Lucas hasn't clogged it, the p/s pump has failed thats all.
Old Jul 1, 2008 | 08:24 AM
aBs0lut30's Avatar
Mike, do you think the gear box is ok? Also, how difficult of a job is it to replace the pump on a Disco2? I was looking through the shop manual and got to the remove the A/C compressor and quit reading cause that made me a bit squeamish... Or is it something I would be better off just biting the bullett and taking to the dealership to let them do?
abran
Jun 30, 2014 12:43 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
