What does this code mean?
Old Feb 26, 2008 | 07:07 PM
jhammerstrom's Avatar
Default What does this code mean?
I have an '01 SE7 and I got my codes read by the dealer. I have one code I wasn't sure about, P0734, gear ratio incorrect? Should I be concerned about this? They did replace the transfer case right before I bought it. I have slightly larger tires than stock, 245-70-16 but I wouldn't think this was it.
I also had codes P0154 and P0134. They replaced both front O2 sensors and the Mass Airflow sensor under my short term warranty. I assume this should take care of those.
Thanks
Old Feb 26, 2008 | 07:42 PM
Default RE: What does this code mean?
Check your tire pressure. I have heard of the wrong PSI setting of codes but cant confirm. The fronts and backs are supposed to be at different PSI.
What does the dealer say about the code?
Go to AutoZone and have the codes cleared and see if it comes back on.
Old Feb 26, 2008 | 07:50 PM
jkid's Avatar
I used to have the PO734 code come on every few weeks or so. One indication is supposed to be a failing MAF sensor. I just erased it and it stayed off for a few weeks. My battery was reading a bit low so I gave it a good long charge and it hasn't come on since. This was a month or so ago, so we'll see if it stays off.
Old Feb 26, 2008 | 08:08 PM
The 734 code is usually caused by a bad MAF, the other two codes are related to both of your front 02 sensors.
How many miles on the truck?
Are you sure they replaced the MAF and the 2 front 02's????????????????????
Old Feb 26, 2008 | 08:23 PM
OK, this makes sense. These were the codes from before they did the work, the check engine light is off now so I assume all is well.
They replaced the front sensors, should I replace the rears? It runs fine now.
Thanks
Old Feb 26, 2008 | 08:24 PM
I forgot to mention it has 94kmi.
Old Feb 27, 2008 | 06:14 AM
jkid's Avatar
With that mileage replace them all.
Old Feb 27, 2008 | 08:51 AM
I agrtee, replace them all using the same brand.
exjeep owner
Jun 1, 2012 08:41 AM
DV57
Mar 2, 2012 06:03 PM
deuteronpsi
May 1, 2007 11:13 AM
bobby82569
Apr 12, 2007 05:09 PM
4x4freak
Apr 10, 2007 12:48 PM
