what is everyone idling at without ac
Old Jul 5, 2014 | 08:16 PM
ls1morethanyou's Avatar
Default what is everyone idling at without ac
what is everyone idling at i dont have SAI or ACE and my ac is off.
I have been chasing down an overheating issue and today i have had enough of it to the point of grabbing my extra fan clutch and drilling through i to lock it up.
what i have found so far is i am idling at 650-670 and the truck progressively gets warmer.
if i adjust the idle to 750 it stays rock solid at 185.
i have the inline thermostat mod with a 180 degree thermostat and before my mudding incident the cooling system stayed at 185.
new water pump on the way as well, then testing for intake leaks and evap leaks as i am getting a p0440
Old Jul 5, 2014 | 09:25 PM
RicketyTick's Avatar
I'm idling at 650 to 670 with no air. approx 750 with air. I run around 194 idling. down to 186 to 188 driving with a grey 180 thermostat. 03 D2
Old Jul 6, 2014 | 04:46 AM
after some more testing i noticed there are silver shards inside the coolant reservoir so now i am sure there is either a water pump issue, no water in oil and no oil in water along with no white smoke out the back and no visual leaks of coolant.
this brings me to my next fiasco, the trans cooler decided to rupture- i went from a few drops of atf (just found out it was leaking) to a a gusher after i moved the pipe some.
Old Jul 6, 2014 | 08:09 AM
dusty1's Avatar
815 w
795 w/o
Cold testing this morning
At op temp
650w/o
670 w
Old Jul 6, 2014 | 08:23 AM
Jared9220's Avatar
Did the trans cooler "rupture" or did the hose just come out? They can be tough to get in there all the way. You wouldn't be the first person on here to have one pop out. I've heard of them coming off on the Highway and making one hell of a mess from the fan blowing it everywhere.
Did you disconnect it at some point to do work?
Old Jul 6, 2014 | 10:13 AM
It ruptured, I was hoping it was the line but that was not the case.
richardgatekeeper
Jul 25, 2007 05:58 PM
eriqcharlz
Jul 3, 2007 09:30 AM
EVN137
May 30, 2007 07:24 PM
2tall4u
Jul 26, 2006 05:50 PM
LANDY1998
Freelander
Sep 18, 2005 09:35 PM
