This is what a failed water pump looks like, right?
Looks like it’s coming out the weep hole? Ivan had a really bad squeak on cold starts that I thought was a bad pulley. Also gurgling coming from the heater core, which always indicates a coolant leak. Such a bummer. This water pump is only 10k miles old.
If its not under warranty with AB then you might want to replace it with the Airtex water pump.
FCP Euro has a lifetime warranty on all of their parts that they sell. Usually prices are a bit higher than elsewhere but the policy is pretty unreal - even wear items are allowed to be returned under the policy (brake rotors/pads, motor oil, etc.)
https://www.fcpeuro.com/products/lan...over-stc4378my
ahab (12-21-2020)
