What grease do you use on your driveshafts?
I have Tom Woods front and rear D/S shafts. I've been using NLGI #2 Valvoline ()
Seems to work great on the u-joints, but I tried using it on the slip joint nipple, and it popped the dust cap off (after consuming A LOT of grease first). I asked Tom Woods, and he said I should be using NLGI #1 grease (thinner) on the slip yoke shaft.
#1 grease seems a lot harder to find and it would be super annoying to have to switch between greases on my air powered grease gun.
Thoughts?
Thoughts?
yeah, I agree any ol grease is fine for the u-joints, but my problem in particular is with the slip joint/yoke shaft. The dust boot separated, apparently due to too thick of grease. The old grease is supposed to ooze out, not push the cap off. And side thought, I can never seem to get grease to ooze out of the entire diameter of the u-joints, usually only like 50% of the circumference... again, too thick of grease? NLGI #2 is pretty standard stuff though...
It's basically brand new and happened the first time I greased it. ~1400 miles. I can't recall greasing the front slip-yoke, so I will try that tomorrow and see if I get the same result. I was pumping grease into the rear shaft with an air gun @ 60 psi for a solid 30 or 45 seconds until finally the cap started to move. That shaft holds a lot of grease...?!
