What the H$%L is this noise in my suspension??
Old Oct 2, 2013 | 06:24 AM
sickws6's Avatar
Default What the H$%L is this noise in my suspension??
So every time I roll over a little bump or crack in the road I hear something from the rear suspension, sounds like something is loose. I checked everything all tight. Could be my springs, isolater is in place. Im stumped, its really annoying.
Old Oct 2, 2013 | 07:50 AM
Perhaps a bushing. See 2004 Land Rover Discovery Suspension Bushing at CARiD.com
Would be hard to eval on the ground, up on a lift may reveal more.
Old Oct 2, 2013 | 09:56 AM
groeder24's Avatar
I was chasing this same noise and it seems to be my drag link. If I rap on the link while parked it I can replicate the sound. Looks like it is coming from the threaded section with the clamps. I am going to try and tighten the two clamps. Mine also looks a tad tweaked.
Old Oct 2, 2013 | 10:08 AM
dusty1's Avatar
Can you hear it if you manually rock the truck, while standing at rear wheel?
Old Oct 2, 2013 | 04:01 PM
acamato's Avatar
Did you check the watts linkage? Lucky8 has a viedo on YouTube on how to check it.
Push, side to side, on the rear of the body.
Old Oct 2, 2013 | 04:16 PM
ZGPhoto's Avatar
I'm with acamato on this, sounds like watts linkage. Does it happen when you back over a bump usually? Here's justin from L8's video on it.
Old Oct 2, 2013 | 04:39 PM
dusty1's Avatar
Me 2 that's why I asked about rocking it
Old Oct 2, 2013 | 09:21 PM
toofaroffroad's Avatar
Watts linkage or warn shock bushings. Both easy to fix or replace.
Old Oct 2, 2013 | 10:03 PM
sickws6's Avatar
Must be watts. It makes sound when just turning sometimes.
Old Oct 2, 2013 | 10:04 PM
sickws6's Avatar
What do I do to the watts
