What the heck happened here? (Throttle body heater)
Old May 20, 2019 | 04:48 PM
Brandon318's Avatar
Default What the heck happened here? (Throttle body heater)
So, took off the coolant hoses from the throttle body heater and looks like they’re all plugged up. Is this common?
Old May 20, 2019 | 05:15 PM
Dave03S's Avatar
That is the combination of Dexcool and air. Which is why Dexcool is only good in a system that will never leak or have air introduced in any way. The TBH probably once had a small leak.
Old May 21, 2019 | 02:29 AM
JUKE179r's Avatar
@Brandon318 ... you can bypass the TBH altogether if you don't live in a cold climate area. They leak all the time.
Old May 21, 2019 | 07:50 AM
redwhitekat's Avatar
What coolant are you using ??
Old May 21, 2019 | 07:59 AM
OverRover's Avatar
Looks like some water and the Home Depot version of Head Gasket Sealer.
Old May 21, 2019 | 09:25 AM
Brandon318's Avatar
I use the BMW blue coolant. This is a relic from the PO. We just got this Disco a month ago and this week I've been working through the major service sticky.
Old May 21, 2019 | 10:05 AM
CollieRover's Avatar
When you replace grab a Genuine kit. I reconditioned the gasket contact surface with 180 then 220. Seems to have worked beautifully. I have heard people just seal using The Right Stuff, but I have not tried it.
Old May 22, 2019 | 12:06 AM
Frank4's Avatar
Delete it. Best fix for a TB heater on a Discovery.
Old May 22, 2019 | 02:16 AM
JUKE179r's Avatar
Hear, hear...
Old May 22, 2019 | 09:22 AM
FlyingZebra34's Avatar
Dexcool is amazing. Fixes its own leaks.
