What kind of springs?Thinking about 3" RTE Springs, Anyone have them?
Old Apr 16, 2014 | 10:13 AM
ZGPhoto's Avatar
More height
Old Apr 16, 2014 | 10:59 AM
primussucks's Avatar
what other geometry changes are required for 3"?
I'm looking at an OME setup...I already have extended brake lines, just need to solder in some ABS sensors now... Just curious about the geometry stuff though.
Will stock rear driveshaft be fine (with rotoflex)?
What about trailing arms, etc.?
Old Apr 16, 2014 | 11:29 AM
Dane!'s Avatar
Lucky8 4.5'' Springs Vs. RTE 3" Springs
I heard that the RTE runs about 4" and you have to use spacers to even the truck out because they use D1 rears. How does L8 compare to this? Direct swap and I get 4.5" of lift with no bs?
Most people can run a 3" with no problem Primus. Steering geometry should be fine and the pinion angles should be good for the roto and not bad for the front diff.
Old Apr 16, 2014 | 11:31 AM
ZGPhoto's Avatar
Radius arms are a good idea, as is adjustable panhard. Cranked watts is a must if you want to articulate at all.
Old Apr 16, 2014 | 11:39 AM
dusty1's Avatar
few things good to-do w/3
castor correction.
space crossmember.
i'd dump rf with 3" due to new angle
adjustable panhard to center axle
btw you can just butt splice some extensions the abs and heat shrink (i'm running low voltage HD wire in the front). my extended ss brake lines are not long enough, imo.(going to have to rig up extensions)
on a truck that is just over 3" and has mild articulation.
Old Apr 16, 2014 | 11:41 AM
ZGPhoto's Avatar
castor correction.
space crossmember.
Don't rig up brake line extensions you sketchball... I'm having custom ones made for my truck, let me know and I'll order you an extra set.
Old Apr 16, 2014 | 11:47 AM
dusty1's Avatar
in....well only if they are pink.
emailing, in 3....2....
Old Apr 16, 2014 | 12:39 PM
Fivespddisco's Avatar
Originally Posted by rchrd0413
Looking for about 3 inches. Got a very heavy bumper,winch soon will be rails, rack under armour, the whole shebang.
The RTE 3in spring will make the D2 sit about 4.5 inches. The TF kit maybe better suited for your 3in needs.
Old Apr 16, 2014 | 01:08 PM
Yoops Racing's Avatar
You are so right! yep got all that as well.....as Tom Woods Driveshafts.
Old Apr 16, 2014 | 01:10 PM
no spacers on mine....got to luv the internet
