What is the most likely cause of my bad MPG on my disco II
Old May 15, 2009 | 04:06 PM
  #21
Originally Posted by VikingDiesel
ok, so BOSCH +4 it is, anyone know where i can get the MAGACORE wires thats NOT online, discomike i believe told me PEPBOYS, but maybe it was for something else. So when I do change the plugs and wires, should I then notice an MPG increase
The only place that I know of to get them for cheap is www.apexperformance.net, call around to autoparts stores and see if they can get them for you if you cant order online.
I also get 20mpg with my DI, on long trips, ~15 as a daily driver.
Old May 15, 2009 | 04:14 PM
  #22
salve7's Avatar
You could remove both the front and back windows, wear an aerodynamic helmet, and tuck when you drive.
Old May 15, 2009 | 04:22 PM
  #23
Just like Ace Ventura!!
Just had the thought that you may have a stuck brake caliper.
Old May 15, 2009 | 05:32 PM
  #24
salve7's Avatar
Like a glove!
Old May 15, 2009 | 08:48 PM
  #25
VikingDiesel's Avatar
where is the cheapest place to buy these wires? how much is it through magnacore directly? also I nedd to know bc everyone different answers, will changing the fuel filter help the mpg? and will just changing the plugs help my mpg and leaving the wires stock?
Old May 15, 2009 | 08:51 PM
  #26
LANDZUII's Avatar
The EPA rated the Classic Disco I's at 14 mpg city and 16 mpg hwy.
I have BFG AT 245/75/16 tyres and will never see 20 mpg hwy with those tyres.
A stock Disco I with street tyres careful driving in good shape can see 20 mpg
BUT this will not be a everyday thing it will be the BEST tank for the most part.
I would think the Disco 2 had a EPA rating less than the Classic Disco I with more hp's 6 of them and more Tq 17 ft lb more.
Now if your Disco has always gotten good fuel mileage (for a Land Rover) then it went to S_ _ _ I would start working on it.
You never said what kind of mileage you get.
Old May 15, 2009 | 08:56 PM
  #27
LANDZUII's Avatar
You have a for the lack of better way of putting it ,,a screen over the pickup on the fuel pump that filters the fuel.
This is what takes the place of a fuel filter on Disco2's and is only changed with the fuel pump ,,, when it goes out.
Old May 17, 2009 | 03:14 AM
  #28
what is the stock plug that came from the factory on a 99 disco II? I just added the bosch 4 plugs on the stock wires and I def noticed my mpg go up
Old May 17, 2009 | 07:10 AM
  #29
Thumbs up
Tire size makes a difference too, as you stated.
I hate to brag (no I dont) but with stock size rubber, the cruise set at 65 MPH, windows up A/C on, me, pregnant wife, 7 yr old daughter, 17 yr old son, cooler full of Pepsi and snacks we got 24 MPG on a 700 mile trip with my DI with over 170,000 miles on the odometer.
It can be done, it is all in how you drive, what oil you use, gas, well tuned, tire PSI, it can be done.
Old May 17, 2009 | 07:11 AM
  #30
They came with Champion spark plugs from the factory.
