What is the most likely cause of my bad MPG on my disco II
Old May 17, 2009 | 08:27 AM
  #31
Get some Magnacors ordered, they will give you a huge increase in power/mileage along with that list I sent you that you have yet to ask about.
Don't waste your time tuning your engine and not do a full service, just to have a major failure that will cost you more then the value of your truck cause you aren't maintaining your truck properly.
Old May 17, 2009 | 09:26 AM
  #32
VikingDiesel's Avatar
wow, if the stock plugs are champions, that explains my bag mpg since they've been on since 99. just a question, but will changing the plugs slightly raise my engine temp? I mean literaly slightly or is it just me? I feel since I changed the plugs yesterday, the mpg did get better but I swear I saw the engine temp needle slightly be a tad higher than the middle but then it went down to the middle, could this be or was it just me?
Old May 17, 2009 | 10:04 AM
  #33
disco mike, 3 questions about your service intervals:
1. which 2 vacuum lines/hoses should I replace, where are they located, and should I replace them only if they are brittle and falling apart?
2. is sea foam like a fuel additive and where can I buy it?
3. about the 2 coolant hoses that I should connect together under the TB, if I do so, won't I have cold weather starting since no coolant will be flowing through the TB?
Old May 17, 2009 | 11:11 AM
  #34
We need some time on the phone. PM me your tel number and I'll call and answer all your questions.
Old May 17, 2009 | 12:36 PM
  #35
You are seeing things.
Copper spark plugs need to be changed every 30,000 miles.
Copper plugs are the cheap ones.
Platninum's will last 60k and Iridiums will last close to 100k.
Old May 17, 2009 | 12:45 PM
  #36
LANDZUII's Avatar
I went on a small trip yesterday and drove 65 mph and 70 mph when the speed limit went up with 10% ethanol (15 % loss) and got 14.3 mpg all highway
Idioteque2
Jan 7, 2015 01:00 PM
88Mwife
Sep 2, 2011 11:49 AM
hilltoppersx
ROAMING WITH FRIENDS
Dec 7, 2010 05:48 PM
Nux
Oct 26, 2005 03:43 AM
06RR06RRS
Oct 9, 2005 04:26 AM
