What motor?
Old Nov 17, 2017 | 07:53 PM
Greg Vasileff's Avatar
Default What motor?
I have been looking for a good cheapo D2 as a parts car (but may also fix it later) for the main reason of rebuilding it's motor and drivetrain to then use in my existing 02.
I'm new and learning, so it's why I ask. I'd like to get a 4.6, ... but is the 4.0 a better choice?
Old Nov 17, 2017 | 08:21 PM
Alex_M's Avatar
That depends on whether or not you're going to have sleeves installed.
Personally, I'd take whichever came along first and just pin or weld the sleeves. That said, if I were not going to do that then I would get a 4.0 block. You can buy a 4.6 rotating assembly (crank and rods) and swap them into a 4.0 block. That will make it a 4.6.
Old Nov 17, 2017 | 09:32 PM
So that's what a 4.6 is? Just a 4.0 with a longer stroke?
Same bore? Same sleeve issues?
Old Nov 18, 2017 | 06:39 AM
Alex_M's Avatar
Same bore, longer stroke, fewer sleeve issues but they still exist.
1999SE40
May 16, 2014 06:48 AM
me 2
Jun 17, 2012 07:24 PM
ColeRover
Feb 9, 2011 07:05 AM
eric2
May 28, 2005 02:44 AM
