What is this in my oil pan?
Old May 6, 2024 | 12:49 PM
AndrewDF's Avatar
7th Gear
Exclamation What is this in my oil pan?
I have a 2003 land rover disco 2 that has developed an oil leak in several places. I thought it was the oil pump or front seal, but when I dropped the pan I found a large flat metal ring (or what looked to be a ring) with small notches on the inside. Does anyone know what this is?
Old May 6, 2024 | 01:11 PM
Gripen's Avatar
Can you post a picture of it?
Old May 6, 2024 | 01:20 PM
AndrewDF's Avatar
7th Gear
Picture was with original post. Not sure why you can't see it.
Old May 6, 2024 | 04:53 PM
mollusc's Avatar
Looks like a broken washer or spacer of some sort. Maybe a camshaft float spacer? (Not sure if these engines have such a thing.)
Old May 6, 2024 | 05:39 PM
AndrewDF's Avatar
7th Gear
Default Not a broken ring, but a whole piece
So I washed the piece and it appears to be whole. Exactly a semicircle with three tabs
Old May 6, 2024 | 05:42 PM
AndrewDF's Avatar
7th Gear
Old May 6, 2024 | 05:56 PM
AndrewDF's Avatar
7th Gear
It’s also magnetic if that helps.
Old May 6, 2024 | 06:57 PM
Extinct's Avatar
Measure the diameter and thickness. looks like the thrust bearing off the crank.
Old May 6, 2024 | 07:33 PM
AndrewDF's Avatar
7th Gear
Diameter is 3.5 inches and the thickness is 1/16 inch.
Old May 6, 2024 | 08:25 PM
Extinct's Avatar
Yep, that is your crankshaft thrust bearing. Gonna need to replace that.
