What new battery? Also, alternator issues?
I have a 2000 Discovery Series II and this morning, out of the blue, I turned the key and got "click, click, click". I tried three or four times. Stopped, was about to call AAA......I gave it one last shot and it started up. The battery was/is the issue because my A/C temp read-out had changed from F to Celsius.
I drive the car 20 minutes to work. Stop, try to restart and "click, click, click,...100% dead. Being that the battery didn't charge up at all after 20 minutes do I also have an alternator problem? Or, could it strictly be the battery? Sorry for such a rookie question, but I'm not a auto guy whatsoever.
If I don't want to go to the dealer.........what are the parameters I should look for in a new battery (cranking amps, etc.)? Please help.
Thanks!
Thanks!
sounds more like a connection issue to me. i would check your ground connection to the vehicle, and clean up the connectors on the battery before i started replacing things.
and as said above, get them tested.
xtina01
Nov 5, 2011 10:18 PM
97_Disco1
Mar 1, 2011 05:38 PM
