What is this plug?
Old Feb 24, 2010 | 11:57 AM
smokey73's Avatar
Default What is this plug?
2003 Disco II
What is this plug? I was doing the spark plug wire change (Magnacor 8mm) and Bosch +4 and when putting everything back together I saw this small yellow two pin plug unattached on the passenger side just behind the fuse box. Any ideas?
Thanks in advance
Old Feb 24, 2010 | 12:08 PM
JEFIII's Avatar
Not sure what it is but, take a deeper look around. That should be attached to a black female end that leads into the fender/firewall. the whole unit should snap on a small cradle like holder.
Hope this makes sense. JF
Old Feb 24, 2010 | 12:16 PM
smokey73's Avatar
Default Do you have a picture?
I checked and can find no female corresonding wire? I also don't see anything attached to the firewall that I can see? A picture is worth a thousand words?
Thanks
Old Feb 24, 2010 | 04:16 PM
JEFIII's Avatar
Default Plug Pictures
Here you go. Hope this helps.
Let me know.
JF
Attached Thumbnails What is this plug?-dscn2478.jpg   What is this plug?-dscn2480.jpg
Old Feb 24, 2010 | 04:25 PM
lipadj46's Avatar
ABS sensor connector
Old Feb 24, 2010 | 05:15 PM
smokey73's Avatar
Default ABS Sensor?
Thats odd, you'd think I would have an ABS fault light of some sort? No lights on the dash.
I'll see if I can find the other end hanging down somewhere.
Thanks for the pictures and info.
Smokey
primey
Oct 26, 2011 07:24 PM
Disco Alan
Apr 21, 2009 06:22 PM
anonimaus
May 1, 2005 05:01 AM
tony kerr
Dec 18, 2004 05:09 AM
