What should be plugged in to this?
Old Oct 10, 2019 | 04:08 PM
greisinb's Avatar
Default What should be plugged in to this?
I just removed the stock running boards on my '99 D2 and as I was crawling back underneath to admire how much easier it is to access the underside of the truck I looked up and saw this:
It's directly under the passenger side front door and was obscured by the running board. There is nothing like it on the driver's side and the truck runs just fine. I don't know what trim level I have so perhaps its something that's wired up but not installed on my trim level? There are two posts directly underneath where its obvious something should go. Thanks for any insight!
Old Oct 10, 2019 | 04:24 PM
Brandon318's Avatar
Photo didn't post :/
Might be something related to air suspension.
Old Oct 10, 2019 | 04:59 PM
greisinb's Avatar
Oops, hopefully it will be here:
Old Oct 10, 2019 | 09:24 PM
greisinb's Avatar
Figured it out! After an extensive look at the electrical manual wherein I just swiped through about 75 pages before I found a matching connector and picture it appears as though this is the mounting point for the lower accelerometer which is used by ACE equipped vehicles. As I do not have ACE the problem is solved! Hallelujah! Finally, an unplugged connector where nothing actually needs to be plugged in!
Davis31052
Dec 31, 2018 08:28 AM
naivedisco2
Jul 11, 2016 11:39 AM
phild870
Dec 30, 2013 10:37 PM
toad2
Oct 9, 2012 06:09 PM
br0keit
Oct 5, 2012 10:18 PM
