What size mud terrains??
Old Sep 22, 2009 | 01:42 PM
oljohnboy's Avatar
Default What size mud terrains??
What is the biggest size mud terrain that can be run on a 98 stock land rover? I have heard that a 245 tire would scrub even with a 3 inch lift so I need help! I know some of you guys have big tires, anyone got suggestions? thanks
Old Sep 22, 2009 | 02:40 PM
hazletbassist89's Avatar
Stock you can run 30" no problems, maybe 31" if you want to push it. On a 3" lift you should be able to fit 33"s with room to spare. All of this with no trimming of course.
You should definitely consider a new OME suspension though, the stock LR coils will start to sag as early as 60-80k miles and a new set up is well worth the money. I'll be getting mine in a few weeks assuming finances permit.
Old Sep 22, 2009 | 02:58 PM
98roverguy's Avatar
My question is what size tires can you run after doing a heavy-duty OME suspension in a DI?
Old Sep 22, 2009 | 03:09 PM
kenk's Avatar
I'm running 245/75 with 2" springs and have no rub at all, although it is really close in the rear when I stuff the wheel fully up into the well.
Old Sep 22, 2009 | 03:20 PM
245 is usually the best bet, with little or no work required.
As for how big a tire can you install, I have seen 12.50/35/15's stuffed in with a fair amount of work and they work really well
Old Sep 22, 2009 | 03:53 PM
98RG to answer your question specifically, I'd say no bigger than 32" and you'll be good to go.
Old Sep 22, 2009 | 04:46 PM
265's won't fit into a D1 with out a lift of at least 2"s plus.
Old Sep 23, 2009 | 01:02 AM
98roverguy's Avatar
Go to www.discoweb.org click on Tech then scroll down to Tires and Wheels.
Found it interesting.
Old Sep 23, 2009 | 08:17 AM
kenk's Avatar
That was pretty interesting. I think it also has alot to do with tire design and manufacturer, they all vary a little bit in size. I dont run full-blown mud tires, but my Cooper s-t's are fairly aggressive.
I could see where a M/T would rub in the rear with no trimming.
IMO, when I mounted up the 245/75, I did have to remove the front mud flaps off the factory running boards
Old Sep 23, 2009 | 09:39 AM
oysterhead's Avatar
why would i not put in a 3" OME instead of 2"?
if i didn't use the long travel shocks, the actual lift is more like 2.5", right?
that doesnt require an mods to brakes, etc.
so why not the 3" lift? what am i missing?
