What size tools for the drain/fill of autom. transmission?
Old 02-22-2009, 12:49 PM
Disco Fuego's Avatar
Question What size tools for the drain/fill of autom. transmission?
I was going to drain the Transmission and fill it again, but I came to the conclusion I do not have the right size tools. Can anybody tell me what size? i can't find that info on RAVE CD either...
Old 02-22-2009, 01:29 PM
Doesn't it take an allen wrench?
Old 02-22-2009, 01:32 PM
llPANCHOll's Avatar
D1 is an 1 1/16th inch open end wrench for the drain plug..
As far as the D2.. Who knows.. get under it with a tape measure or a micrometer and take a look
Old 02-22-2009, 01:40 PM
Yes it does take an allen wrench on the D2. I tried both sets I have, but no luck... The drain appears to be in between 3/16 and 7/32, and the filler is bigger than 1/4. Rather than buying a whole bunch of tools I just wanted to go buy the exact sizes for the job...
Old 02-22-2009, 01:43 PM
So I should go and buy a micrometer now... A tape measure would not be accurate enough. The idea was to save money insteaad of buying a bunch of tools that won't do me any good... I guess somebody needs to support the economy!
Old 02-22-2009, 02:13 PM
roverguy7's Avatar
its metric. 5mm for the drain, and 8mm for the fill
Old 02-22-2009, 02:50 PM
Thanks! Just got back from Autozone and bought a set of metrics that had a big range including the 5 and 8 mm.
Now, let's get back under the car!
Cheers!
Old 02-22-2009, 03:47 PM
That is for the engine oil drain plug, the SDI trans drain plug is like 15mm or such.
He is doing his transmission.
Old 02-22-2009, 05:26 PM
5 and 8 did the trick...
Now, question... I was able to add almost 4.5 quarts. Once it started coming out of the fill hole, it wasn't just a 2 mm bead. It came out like in a (little) stream. I quickly closed it, but now I am wondering if I overfilled it. Is that possible? and if so, is that bad?
Old 02-22-2009, 05:32 PM
Street Wolf's Avatar
Did you start the truck and continue filling?
Quick Reply: What size tools for the drain/fill of autom. transmission?
