What is supposed to be on spare tire mount?
Old Mar 1, 2024 | 10:08 PM
Roont's Avatar
Default What is supposed to be on spare tire mount?
Mine came with the spare tire and holder in the back cargo area. I have the 2 brackets and 6 long bolts and nuts as well as the actual holder.
But the part where the tire mounts has one crazy crackhead welded snapped stud and 2 holes.
What is normally there? Welded studs?
One idea was use the m14x1.5 lug bolts from all the German cars in the shop and get 3 new discovery lug nuts?
Or if the cones match, weld nuts onto carrier and use the bmw lug bolts?
Kind of overthinking it but these tires are heavy and I don't want to murder anyone behind me
Old Mar 2, 2024 | 07:28 AM
NVDiscovery's Avatar
Sounds like you need a new spare tire mount. If you have larger than stock tires, then you'll want to consider the spare tire relocator.
Old Mar 2, 2024 | 11:08 AM
gecko951's Avatar
My stock tire carrier was in bad shape too so I swapped mine to the TF499 HD tire carrier and its a nice upgrade.
https://lucky8llc.com/products/h-d-h...ier-terrafirma
Old Mar 2, 2024 | 03:47 PM
mln01's Avatar
Originally Posted by Roont
Mine came with the spare tire and holder in the back cargo area. I have the 2 brackets and 6 long bolts and nuts as well as the actual holder. But the part where the tire mounts has one crazy crackhead welded snapped stud and 2 holes. What is normally there? Welded studs?
Rather than trying to rig something to work, I expect you could get one from a boneyard truck for only a few dollars. Since you're in New Jersey there may be a DII in a salvage yard near you. They're on the self-service yards here only rarely these days.
Or, check with Will Tillery. He has a yard full of parts trucks and I don't expect spare tire carriers are a high-demand item.
Old Mar 2, 2024 | 07:26 PM
Roont's Avatar
Can't afford a new one, spent all my money on glitter spray paint 🤣
Old Mar 3, 2024 | 08:44 AM
For sure you can buy a used tire mount. Just be sure that the bolts are totally secured as the weight of the tire puts a lot of stress on the bolt area. I had my original mount tear at the bolts and was amazed at how the spare tire wobble made the whole truck shake. That's why I recommended a new mount. BTW, the first new mount that I bought arrived damaged and had to be replaced so carefully inspect whatever you purchase new or used.
Fallstaff
Feb 3, 2018 01:35 AM
No Doubt
Aug 7, 2017 12:40 PM
No Doubt
Aug 6, 2017 07:53 PM
CarParter
Jul 18, 2017 09:01 AM
Landzu
Oct 16, 2007 06:49 AM
