What tires can I fit on my DII?
Old May 13, 2015 | 12:49 AM
User Name's Avatar
8th Gear
Default What tires can I fit on my DII?
Hey guys, I am in dire need of replacing the tires on my 2000 DII. I know it currently has 255/65-16's on it, but they just seem so small in the wheel well. Have any of you guys experimented with any different tire sizes? some answers would be fantastic! Thanks
Old May 13, 2015 | 09:21 AM
robert.juric's Avatar
I have this bookmarked: Basic Tire Information - Land Rover Forums : Land Rover and Range Rover Forum
To extract from that page:
Discovery Series II 99-04
<29"
255/65/16: Stock tire size.
255/55/18: optional stock size.
30"-31"
255/55/19: stock size for range rover III. works fine for DII
255/70/16: a little taller than stock.
245/75/16: a little taller than stock. tire manufacturers recommended these be fitted with 7" wheels, but 8" works fine.
32"
275/70/16: possible to fit without lift. minor rubbing.
265/75/16: possible to fit without lift. minor rubbing.
285/60/18: 32" tire for the 18" rim. costs much more than 16".
33"
285/75/16: even taller than 265/75-16, requires around 3" of lift. Very wide and requires trimming. consider upgrading to hd axles & getting lower gears.
255/85/16: a bit taller than 285/75-15 but narrower. consider upgrading to hd axles & getting lower gears.
Old May 13, 2015 | 10:32 AM
User Name's Avatar
8th Gear
oh nice thanks a ton man, the Rover is not lifted so would you say without rubbing the largest tire I could fit on there would be the 245/75/16?
Old May 13, 2015 | 10:52 AM
I just copied this info since I'm waiting to do the same thing. I'm not claiming I came up with that by any means. I'm not really sure what that little note mean on the 245/75R16 regarding the 7/8" wheels.
But they come out about the same:
255/70R16 = 30.1" diameter, 10.04" width
245/75R16 = 30.5" diameter, 9.65" width
I'm going to try and wait for a 2" lift and put something slightly larger on.
Old May 13, 2015 | 11:24 AM
drowssap's Avatar
narrower tire = narrower rim
Old May 13, 2015 | 11:31 AM
User Name's Avatar
8th Gear
would you say 245/70 is too narrow?
Old May 19, 2015 | 09:17 AM
cornbreadj's Avatar
I got 265/65 18 on my 2003
Old May 19, 2015 | 09:22 AM
cornbreadj's Avatar
This is what it looks like with 265/65 18 on
Attached Thumbnails What tires can I fit on my DII?-20150510_171737_001.jpg   What tires can I fit on my DII?-img_20140518_082034_898.jpg
Old May 19, 2015 | 11:30 AM
cornbreadj's Avatar
The first pic is stock tiers
Old May 19, 2015 | 05:35 PM
disc0man's Avatar
No, that's not too narrow. I run a 235/85 r16 on my stock wheels. Not the best of rim protection but just don't run into anything.
