What ultragauge items do you find most useful to measure?
Old Jul 11, 2020 | 11:09 AM
Brandon318's Avatar
Default What ultragauge items do you find most useful to measure?
Both of my Discos are set up to primarily show coolant temps, obvi, and battery voltage. What are some other measurements you all find useful?
Old Jul 11, 2020 | 07:33 PM
Sean Maginness's Avatar
I watch coolant temp, intake temp, battery voltage, and air flow. I’ve killed a couple MAF sensors by getting water into the airbox and down the intake even filling the resonator deal with water, so I like to watch that measurement now.
Old Jul 11, 2020 | 09:17 PM
SundayFunday's Avatar
what numbers are your monitoring your MAF at?
Old Jul 12, 2020 | 12:06 AM
I watch it at idle, at steady load, and if it‘s following engine RPMs up and down. Basically to get an idea if it’s working. When I have killed them the readings are static or significantly lag engine RPM along with rough running.
abran
Jul 14, 2016 12:51 AM
houm_wa
Aug 5, 2015 11:17 PM
film842
May 10, 2015 08:45 AM
Rover Dawg
Dec 15, 2012 10:09 PM
sorbet35
May 8, 2012 08:29 PM
