What is this warning light?
Hello there, i have a warning light come up on the dash when i press the brake peddle, it goes off when i take my foot off the peddle back on when i press again etc. etc.
I have looked in the manual but this isnt in there!?
Picture attached. , it is the one below the hand brake light.
If your break fluid is low and you have no leakes then check your pads, both front and rear. If you were to put fluid in then notice you need to change your pads then when you compress the pistons back your new break fluid will spill out every where and it it's not great for the paint work on the bulkhead.
When did you last check your your pads and rotors? As the pads wear down then the fluid will drop accordingly. Its a closed circuit so low fluid is an indication you going to need to look at your breaks. my $0.02
Hi Guys thanks for your replies.
The top light as i said in my initial post is the for the hand brake (parking brake) and goes off when i release it.
The issue is the bottom light which as i now know thanks to you is the Center Diff Lock. The light also comes on when in reverse, im guessing it could be a wiring problem.
Any suggestions?
Any suggestions?
