What is this warning light?
Old Apr 23, 2013 | 05:50 AM
rob01189's Avatar
3rd Gear
Default What is this warning light?
Hello there, i have a warning light come up on the dash when i press the brake peddle, it goes off when i take my foot off the peddle back on when i press again etc. etc.
I have looked in the manual but this isnt in there!?
Picture attached. , it is the one below the hand brake light.
Old Apr 23, 2013 | 05:56 AM
Racer X's Avatar
That's your center differential lock indicator.
What year is your DII?
Old Apr 23, 2013 | 06:02 AM
rob01189's Avatar
3rd Gear
Its a 51 plate, so 2001.
Old Apr 23, 2013 | 08:30 AM
Just in case you have a mis-wired connector somewhere, check brake fluid level. The RAVE circuits manual shows the wiring routed thru a header connector in the center console, where spilled drinks do strange things.
Old Apr 23, 2013 | 07:06 PM
jfall's Avatar
the top one ! is probably the brake level sensor.
Put in some brake fluid.
The bottom one is for the CDL.
You should not see the H CDL light if not in CDL.
Old Apr 23, 2013 | 07:18 PM
roverguy7's Avatar
Check the operation of your brake lights, with your headlights switched on. Never seen it with the CDL light, but if you have a bad ground for a tail light, it will usually light up the rear fog light indicator.
Old Apr 23, 2013 | 08:18 PM
909wheeler's Avatar
Brake fluid is low. When you step on the pedal fluid is drawn from the master cylinder causing the level to drop below the sensor limit. When you release the brake, the reservoir fills back up just enough and the light goes out.
Old Apr 23, 2013 | 09:21 PM
G Reeves's Avatar
If your break fluid is low and you have no leakes then check your pads, both front and rear. If you were to put fluid in then notice you need to change your pads then when you compress the pistons back your new break fluid will spill out every where and it it's not great for the paint work on the bulkhead.
When did you last check your your pads and rotors? As the pads wear down then the fluid will drop accordingly. Its a closed circuit so low fluid is an indication you going to need to look at your breaks. my $0.02
Old Apr 24, 2013 | 03:40 AM
rob01189's Avatar
3rd Gear
Hi Guys thanks for your replies.
The top light as i said in my initial post is the for the hand brake (parking brake) and goes off when i release it.
The issue is the bottom light which as i now know thanks to you is the Center Diff Lock. The light also comes on when in reverse, im guessing it could be a wiring problem.
Any suggestions?
Old Apr 24, 2013 | 05:42 AM
coors's Avatar
The CDL light is controlled by a mechanical switch that sits atop the transfer case. You say, it also comes on in reverse? Hmmm? Most of the time those lights don't work when the CDL is engaged...
