What is what under here?
Need a little help distinguishing what bushings are what here, would appreciate your input!
1) track rod
2) panhard
3) drag link
4) ?
5) ?
6) ?
7) ?
8) steering dampener
9) upper front radius
Please correct me if I'm wrong, just giving my best judgement.
And was always curious what the empty holes are where the blue question mark and arrow point too?
Thanks!
1) track rod
2) panhard
3) drag link
4) ?
5) ?
6) ?
7) ?
Thanks!
Cool so does this look right then:
1) track rod
2) panhard
3) drag link
4) lower ball joint
5) upper ball joint
6) lower sway bar
7) upper sway bar
And the hole is for right hand drive steering
ZGPhoto (05-30-2018)
WOW is that rig CLEAN!!!!!!!!!!!!!!!!
8 > DRAG LINK ( w/ Steering Damper mounted to it)
1 > Tie Rod End @ Steering Box Drop Arm
2 > Panhard Rod
6/7 > Anti Rollbar/Swaybar Link End
9 > Radius Arm
4 > Lower Ball Joint
5 > Upper Ball Joint
3 > TRACK BAR ( Plus Outer Tie Rod End )
"BLUE Arrow", where the Drag Link outer tie rod would mount on a RH Drive truck.
