What in the world is this under the TB??? Apparently it needs replacing.
Old Dec 22, 2014 | 02:15 PM
  #21
LandRoverDisco03's Avatar
Yes thank you. I see that...
As of now the strangest thing is happening and I have a thought but I'm just not sure...
Once I go through the procedure the truck is fine at idle. As soon as I start to drive though the truck overheats and when I pop the top STEAM is coming out of the over flow tank...
So my question is this... For testing purposes I have been using 100% water in the cooling system. No mixture what so ever. Is this improper? I have been doing so because I don't want to just buy gallons and gallons of antifreeze/dex cool if my problem still persists.
Please advise... Going crazy.
Old Dec 22, 2014 | 02:19 PM
  #22
dusty1's Avatar
water is ok for testing....should be distilled. but straight water cools better than mixed.
it sounds like you could have exhaust gas in the cooling system.
i would do the chemical test
Old Dec 22, 2014 | 02:22 PM
  #23
When you say exhaust is in the cooling system... What could be the cause of that?
I'm very new to LandRovers as my vehicle was a rotary... I'm at a small loss and at the moment don't have the resources to take it to a mechanic.
Old Dec 22, 2014 | 02:25 PM
  #24
dusty1's Avatar
if this is the case, the cause is likely a failed head gasket
Old Dec 22, 2014 | 02:42 PM
  #25
...aye, a failed head gasket...
I'm researching what the possible symptoms are for that. I'm praying that it's not that but I guess there is some way to test that?
I thought if water was getting into the motor than I should see residue or something coming out the exhaust system... And why is that at idle the truck is fine? It's only when I attempt to drive it?
Old Dec 22, 2014 | 02:58 PM
  #26
ZGPhoto's Avatar
Dusty provided a nice GIF of the tool used to test for a failed HG
Old Dec 22, 2014 | 06:09 PM
  #27
lordmorpheus's Avatar
Yep. That combusion leak tester is available for rent at most of the larger auto parts stores. (you just can't return the fluid)
I still have my 1st gen Rx7 in my garage. That was my first toy and may someday make it back to the road. It is currently storing various LR parts on the hood and roof.
Old Jan 31, 2015 | 11:56 AM
  #28
tonydliu's Avatar
My 2003 discovery has the same exact leak with throttle body heater head. ordered the kid from British atlantic. Found a good write up by Josh under 'throttle body heater repair", but all the photos are unavailable. Does anyone have a detail instructions? Thanks in advance.
gillart
May 26, 2015 11:25 PM
Elspode
Jul 19, 2013 10:20 PM
MARSRover
Jun 22, 2012 01:47 PM
Baylink
Apr 11, 2010 01:51 PM
justjack
Jan 12, 2009 07:45 AM
