What's the best source for Injector O-Rings?
Old Jun 25, 2014 | 11:32 AM
ralphobell's Avatar
Originally Posted by Jared9220
Yeah I knew that about the ultrasonic cleaning. I have 2 options for that and I have not yet figured out which to go with.
1) Buy the OTC 3398 Fuel injector pulser to run the injectors in the ultrasonic- ($150)
OTC 3398 - Fuel Injection Pulse Tester | O'Reilly Auto Parts
2) Buy this flow bench and ultrasonic cleaner machine off EBay. $545
New Auto Six Jars Gasoline Fuel Injector Tester and Cleaner MST A360 220 110V | eBay
This machine does it all:
1.Ultrasonic cleaning , dismantle the carbide of the injector
2.injector test. stimulate engine runing condition, test injector in different speed range,Check and test injectors’s injection situation:atomization/sprayingangle/spraying mount/spraying uniformity
3.leakage and block test
4.Uniquely designed various compound bonder for all kinds of side-inlet injectors
5.With reverse flush function, to clean inside out, to improve clean efficiency
6.With a set of adaptors to clean injectors without dismantling it from the engine
Option 2 is more expensive but I might be able to make some money with it to off set the cost. I was thinking of just charging $25 to clean and flow test all 8 injectors for my fellow members on here. The local shop here wanted $15per injector.
Hell if your willing to spend that kind of money then just send the ones out to have cleaned and rebuilt. I've seen pricing from $11 to $25. They give you before and after flow rates.
I just used a 9v Battery and a momentary button hooked to an old injector connector. Cycled each one by hand while it was cleaning. Only thing I didn't have was a before and after flow test.
Old Jun 25, 2014 | 11:34 AM
ralphobell's Avatar
Originally Posted by SuperSport
KY also makes things swell.
In most instances the swelling has already occurred before application....
dougn
Jun 15, 2015 07:37 PM
justinthorpe
Nov 27, 2013 02:53 AM
tylor36
May 22, 2013 12:31 PM
sloppyjoe
Aug 24, 2010 08:44 PM
Granite Disco
Aug 20, 2008 07:17 PM
