What's the consensus choice for high mileage tranny fluid?
Old Aug 11, 2013 | 03:13 PM
DISCO JAK's Avatar
Default What's the consensus choice for high mileage tranny fluid?
I'm gonna be doing a filter and fluid change next week, and wanted to know what the forum's choice is for a high mileage tranny fluid? I was gonna go with this
Castrol 06812-6PK Transmax High Mileage Automatic Transmission Fluid - 1 Quart, (Pack of 6) : Amazon.com : Automotive Castrol 06812-6PK Transmax High Mileage Automatic Transmission Fluid - 1 Quart, (Pack of 6) : Amazon.com : Automotive
but wasn't sure if there was a better choice. I also plan on using some Lucas transmission additive as well. Any help is appreciated.
Old Aug 11, 2013 | 04:38 PM
Since torque converter does not drain, order enough fluid to do multiple changes with drive in between to dilute what is left inside the tranny innards.
Old Aug 11, 2013 | 05:55 PM
Vavoline makes a great High Mileage ATF. If you fluid is brownish or smells burned do 2 drain and refills in a row after letting it idle for a couple of minutes in between changes and consider a bottle of Lucas Tranny additive on the last refill.
By the wayif you need to do it twice then buy 11 quqrts of ATF and a bottle of Lucas.
Old Aug 11, 2013 | 06:50 PM
ShaggySE7's Avatar
I haven't looked into this too hard on the Rover yet but what about a complete flush in the driveway. I have done this on Land cruisers and my Toyota motorhome.
-Drain and replace filter
-Put it back together
-Fill trans back up
-disconnect return line from trans cooler somewhere(this is the part I'm not sure about on a Rover)
-Have someone start the engine
-let the pump pump out about one to two quarts into a container. (I use a clear bottle with a mark at 2 quarts.
-Stop engine and refill trans with the 2 qts you just pumped out.
-Repeat this process until clean fluid is coming out of the return line or you have replaced the total amount the trans holds according to RAVE. Or both!
I have done this with great success in the past. It is a 100% passive flush!
The only thing I'm unsure of is where to disconnect the return line. I'm planning to do this on mine soon if its feasible.
Old Aug 11, 2013 | 06:57 PM
ShaggySE7's Avatar
One more thing. My older Toyota's used DEX 2 or 3. when I did this flush I used the new spec DEX 6. Shifting was smoother and it is a better product. It is synthetic. I use the Walmart brand at $4.25 a quart then do a drain and fill each spring with the same.
just my 2 cents
1998DiscoverySE
Jul 20, 2012 08:02 PM
kaiser
Apr 28, 2009 10:56 AM
LRScott
Mar 4, 2009 08:39 AM
4x4
Freelander
Sep 2, 2007 04:28 PM
joedef90
Defender
Jul 5, 2007 05:06 AM
