whats your highest amount of miles out of one tank?
Old Jun 9, 2018 | 06:27 AM
  #41
OffroadFrance's Avatar
D2 TD5, 550 - 600 miles on one tank of diesel on an autoroute at 60-80 mph variable.
Old Jun 9, 2018 | 06:49 AM
  #42
The Deputy's Avatar
Been averaging about 285 mile per tank full, 14.2. Using Sunoco mid grade lately (89/90?), smooth idle, decent mileage considering what were dealing with here. This is no expressway driving, rural roads/back and forth to work.
Brian.
Old Jun 9, 2018 | 09:38 AM
  #43
Best4x4's Avatar
I just did 239 miles when the low fuel light came on. I did a ton of stop/starts (thank you Houston, TX........), then once free of that BS I was running between 80-85MPH, so not to bad IMHO with a lifted, loaded down D2.
Old Jun 9, 2018 | 11:17 AM
  #44
The Deputy's Avatar
As mentioned in post #24, figuring out your exact miles is paramount. My stock tires, 255/60-16 were 29 inches diameter...whereas...my 265/75-16'S are 31.5 inches in diameter.
My odometer is off about 10.5 miles pre 100. So, when I say it had 285 miles last check...the odometer actually said l'd gone 260 on my 01. Math is necessary.
I've been afraid to actually check the mpg on my wife's 03 (04 engine). Although it has no codes and runs smoothly...it is God awful on fuel mileage. Stock tires and suspension, but for whatever reason...she only gets about 200 miles out of a tank (maybe). Luckily, she only puts about 3000 miles a year.
Brian.
Old Jun 9, 2018 | 03:50 PM
  #45
I'm running on 50% worn 255 50 R19 Continental top range road tires, they are equivalent to stock tires in overall diameter, 255 55 R18. My next set of tires will be either Falken Azenis FK510 or Atturo AZ 850, both types have great wet grip.
Old Jun 12, 2018 | 01:15 PM
  #46
Big Jim Swade's Avatar
I usually get between 200-280 miles in my Disco. But my 08 Mini Clubman S I've gotten over 500 miles on it's 13.5 gallon tank
Old Jun 13, 2018 | 02:41 PM
  #47
The Deputy's Avatar
The gas gods must like me this tank...288.6 (odometer) + 28 (odometer discrepancy/larger tires) = 316.6 miles ÷ 20.5 gals of fuel = 15.44 mpg.
Only differences over last tank...changed idler pulley/belt after failure, welded exhaust y-pipe at manifold and dropped out 15W40 after overheating and added 10W30 (bought cheap oil incase engine was toast after overheating, will change soon). I believe it was running a little rich because of the exhaust leak, black ring around end of tailpipe.
Been getting 14.2 reliably forever...so, l have to see these results again before I start the year long celebration and buy a round for the house!
Brian.
Old Jun 14, 2018 | 10:29 PM
  #48
Saturnine's Avatar
I'm at just above a 1/2 tank and have driven about 150 miles thus far..
Old Jun 15, 2018 | 03:11 AM
  #49
The Deputy's Avatar
That's about where I would be when getting 14.2 mpg, around 150 at half tank and a little less on the second half, 120 mpg. I've checked the last six or seven tanks and always the same, 14.2.
Then this last tank blew me away, l knew something was up when it got to a half tank and she had 169 miles.
Brian.
crackofnoon
LR2
Jul 18, 2019 08:04 PM
Roverwhelmed
Feb 18, 2019 10:56 PM
AbnMike
Apr 10, 2017 06:47 PM
Sam95disco
Mar 14, 2014 05:09 AM
llPANCHOll
Mar 13, 2009 05:06 PM
