Wheel bearings
Old 11-09-2010, 09:13 AM
fivecornersmike's Avatar
Default Wheel bearings
is there a good way to isolate witch wheel bearing is bad ? if i start replacing all it will get very $$$
Old 11-09-2010, 09:22 AM
DarylJ's Avatar
The one that makes noise or is loose when you jack that wheel off the ground and shake it.
You really need to be more specific if you want a good answer.
Old 11-09-2010, 09:24 AM
why do you think a wheel bearing is bad? do you have the 3 amigos?
Old 11-09-2010, 02:41 PM
lipadj46's Avatar
read your ABS codes.
Old 11-09-2010, 02:58 PM
bosshogt's Avatar
Also if you spin each wheel individually while the car is jacked up. Hold your hand on the spring...You can feel/hear a grinding sound. Thats the wheel with the bad hub. The hub has to be really worn out to feel any movement top to bottom.
Check eBay for a used hub. New hubs run about $400. Used ones are $60 to $100 on eBay. Its more likely your front hubs are worn out...from steering, braking and driving. My front right when bad at about 75k. Its a 3 hour job, by the time your beat off the disc brake rotor, but totally doable. Be gental taking out the ABS sensor line. Rent a hub puller from an auto parts store for free.
Old 11-09-2010, 03:01 PM
Have you tried jacking up 1 wheel at a time and wiggle the tire from top to bottom?
Are you sure it is a wheel bearing and not one of your brakes dragging?
Old 11-10-2010, 07:44 AM
thanks i will try all the good info ! thanks again
Rover Curious
12-23-2011 05:26 PM
NiveK1970
10-28-2009 11:12 AM
bklahl
10-12-2006 04:38 PM
bklahl
10-10-2006 03:11 PM
sanmigmike
08-24-2006 03:37 PM
Quick Reply: Wheel bearings
