wheel drift
wheel drift
I've replaced my shocks and springs. Track rod has been replaced 5 years ago. And I still drift in the lane, especially when driving at higher speeds, Checked all wheels for side to side movement. Nothing. Tight as a frogs ***. What would be the cause of such erratic behavior? Its sometimes a struggle to stay in one lane, but not enough to be considered dangerous. What should I look for?? 2002 Discovery 2.
Before all the modern jigs came in they use to do a thing called a "Drop test" this is simply putting your car on a flat surface the using a pointed plumb bob, mark out the chassis points and axle point marking the points on the floor, move the car then measure the reference points to see if there is an significant deformation, then pin your steering on the drop bar, by inserting a drill to centre the steering
the simply tie a long length of string on the rear I use my tow bar, pull it tight across the rear wheel at the centre of the hub forward to the front wheel centre of the hub, this will tell you if your front wheels are not in line, toed in , toed out, but they should be the same,
It should be
Toe out – Front – 0° 10' ± 0° 10' (total)
! Toe in – Rear + 0° 5' ± 0° 15' (total)
Basically the front are parallel, so if you need to adjust the steering you start with the drag link side , centre the steering with the drill, adjust the drag link side wheel, when you happy with that the do the other wheel on the tie bar if you done have grease plates under the wheels
It should be
JohnZo (07-09-2021)
1998DiscoverySE
02-10-2012 11:00 AM
