wheel hub Question
Old Jan 5, 2013 | 05:09 PM
thehrdway's Avatar
Default wheel hub Question
does the hub on a 99 disco ii need to be pressed on or can i gently whack it back onto the spline?
Old Jan 5, 2013 | 05:20 PM
mtrdrms's Avatar
It's a unit bearing I think and it shouldn't need to be pressed on.
Old Jan 5, 2013 | 05:31 PM
thehrdway's Avatar
it is a unit just a liitle concerned ..im at that point about to go get a puller on sat night and dont wanna get stuck first one ..
Old Jan 5, 2013 | 05:36 PM
thehrdway's Avatar
oh yeah and i tore up a puller but not a thrree jaw
Old Jan 5, 2013 | 06:21 PM
Racer X's Avatar
Clean and lube the splines before reassembly. Use the axle nut to pull the axle into the hub/ bearing assy once you have the splines lined up.
For the unit bearing, pull that into the knuckle by using the mounting bolts, gradually tightening in a star pattern until fully seated.
Old Jan 5, 2013 | 07:41 PM
thehrdway's Avatar
im done thank you for the reply the three jaw works great
Old Jan 5, 2013 | 08:59 PM
thehrdway's Avatar
okay so any input would be appreciated ......
replaced the left side hub still and its still making the noise.
it makes a noise that goes away when i turn right and some time at high sppeds. sounds like (wow wow wow wow) .... any ideas are appreciated
Disco Alan
Mar 27, 2009 07:50 PM
Quiksilver1850
Nov 25, 2008 01:05 PM
Tvdmtac
Sep 18, 2008 07:17 PM
bmayer01
May 11, 2008 10:38 AM
Disco Doc
Jan 10, 2008 01:17 PM
