Wheels hard to remove
If the roads were bad and we absolutely had to go out, we also had a winter beater Nissan Pathfinder with a plow blade and good winter tires on it.
Now that we've moved from semi-suburban Newfoundland to rural Nova Scotia and no longer have the Pathfinder (bought back by Nissan after a front suspension tower rust issue recall), we'll be looking at snow tires for next winter.
Forget about all that liquid stuff that helps free up tires from the hub. Get a 2x4 about 1ft long and a sledge hammer at least a 3 pound one. Put the 2x4 on the edge of the rim near the tire and beat it off. You will need to start on one side and go left to right and up and down in a cross pattern on the edge of the rim. This will work. I keep a 2x4 and a sledge hammer with me at all times cause I've had this happen a lot and it will not damage your rims.
Really? I had a P38 that was missing 2 center caps and was used in the winter in New England (lots of salt) and after I bought it I had to use a hammer to get the wheels without the caps off. I cleaned up the mating surfaces, added a little never-seize and after that the wheels practically fell off whenever I loosened the lug nuts. On my DII, I have never had an issue pulling a wheel off by using the same approach. I think I'll stick with the never seize and leave the hammer at home in the toolbox.
well antiseize is the why to keep it from happening,AGAIN.
The easiest way I found to get the wheel off was to lossen to lugnuts a 1/2 turn make a figure 8 to the right and one to the left. pulled back in the driveway and the wheels came off on my dII and my RRC.
*Note I did not say drive it down the highway at 70 mph nor did i say you to take the lugs off and go to McDonalds to get lunch*.
well antiseize is the why to keep it from happening, the easiest way I found to get the wheel off was to losen to lugnuts a 1/2 turn make a figure 8 to the right and one to the left. pulled back in the driveway and the wheels came off on my dII and my RRC.
*Note I did not say drive it down the highway at 70 mph nor did i tell you to take the lugs off and go to McDonalds to get lunch*.
wheelgarage
10-01-2011 03:12 PM
trioinfo
06-03-2008 02:00 PM
