When should I change Transmission Filter???
my sister has a 2004 Disco and it has 39k on it and I would like to know if I should change the tranny filter, and also how do you check the tranny fluid????
Thanks,
Thanks,
Didn't she have the free 30,000 miles service that Rover would have paid for, if not, you are 9000 miles late.
If it was done, under normal circumstance the next filter change is at 120,000 miles with fluid changes every 30,000.
Do not assume that it has been done, if you have no records of it being done then it was not done.
To check the fluid there is a fill/check plug on the side of the transmission, drive it around the block, park it on a flat surface and with it in park and running remove the fill/check plug, it shold be right at the top.
It takes Dexron III.
Change your filter every 60k (after the first filter change at 30k)and the fluid every 30k.
So assuming that the trans filter has been changed at 30,000 miles, change the fluid at 60,000 and the filter at 90,000, then repeat.
120,000 change the fluid, 180,000 the filter again.
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
cpn LR
Jul 9, 2010 05:18 PM
