When should I change Transmission Filter???
Old Jun 8, 2009 | 06:01 PM
richey50's Avatar
Default When should I change Transmission Filter???
my sister has a 2004 Disco and it has 39k on it and I would like to know if I should change the tranny filter, and also how do you check the tranny fluid????
Thanks,
Old Jun 8, 2009 | 06:15 PM
Didn't she have the free 30,000 miles service that Rover would have paid for, if not, you are 9000 miles late.
If it was done, under normal circumstance the next filter change is at 120,000 miles with fluid changes every 30,000.
Old Jun 8, 2009 | 07:47 PM
Do not assume that it has been done, if you have no records of it being done then it was not done.
To check the fluid there is a fill/check plug on the side of the transmission, drive it around the block, park it on a flat surface and with it in park and running remove the fill/check plug, it shold be right at the top.
It takes Dexron III.
Old Jun 8, 2009 | 07:58 PM
Night Train's Avatar
Disco Mike,
The owners manual for my '04 says to change it a 30k and never touch it again - am I missing something?
Thanks
Robert
Old Jun 8, 2009 | 08:09 PM
richey50's Avatar
Thank you for that info and I just called the dealor and they said they have done it at 22,500, so I guess we are good and I will check the level, once again thanks.
Old Jun 8, 2009 | 08:21 PM
Originally Posted by Night Train
Disco Mike,
Thanks
Robert
The owners manual also says to change the oil every 7500 miles, do you listen to that too?
Change your filter every 60k (after the first filter change at 30k)and the fluid every 30k.
So assuming that the trans filter has been changed at 30,000 miles, change the fluid at 60,000 and the filter at 90,000, then repeat.
120,000 change the fluid, 180,000 the filter again.
Old Jun 8, 2009 | 08:54 PM
I added the 120,000 filter change just as a safe guard.
Old Jun 8, 2009 | 09:39 PM
Mike - Spike,
K - I understand
collin Barrows
Aug 28, 2011 07:13 AM
kentuckyroverman
Jan 3, 2011 10:47 AM
treant985
Dec 27, 2010 02:51 PM
cpn LR
Jul 9, 2010 05:18 PM
texmanmoore
Feb 23, 2008 02:39 PM
