Where can I find the male connector for the trailer lead passenger tail light?
Old Jan 12, 2025 | 10:12 PM
Frank4's Avatar
Default Where can I find the male connector for the trailer lead passenger tail light?
Atlantic British offers a kit that has the male connector but an hour long search for just the male connector yielded zero results. Has anyone ever tracked one down?
Old Jan 12, 2025 | 11:04 PM
gecko951's Avatar
Remove the passenger side tail light and the connector should be there unless a PO hacked around back there...at least it was on my truck when I installed the AB kit years ago.
Old Jan 13, 2025 | 07:50 AM
Frank4's Avatar
Yeah that’s the female end of the connector. I am looking for the male end take a look at the pictures with arrows pointing to the male end.
Old Jan 13, 2025 | 08:40 AM
mollusc's Avatar
There shouldn't be a male end on the truck. If you don't have a harness plugged in there's just a cover on it.
The male plug is on the adaptor harness.
Old Jan 13, 2025 | 09:58 PM
Frank4's Avatar
Yes you are correct, if I had one on the truck would be able to find it. I am looking to source just male connector without buying the trailer kit. I can wire a male connector to fit my needs I just can’t find one.
Old Jan 13, 2025 | 10:09 PM
disco96sd's Avatar
try ebay if you are concerned about the price of a new kit - maybe you can find a used trailer kit
Old Jan 14, 2025 | 05:55 PM
Frank4's Avatar
not looking for a kit to wire a trailer. Looking for the male connector for another project.
Old Jan 19, 2025 | 09:48 PM
nashvegas's Avatar
Best bet is a salvage yard -- tons of wrecked D2s at Pick N Pulls have the trailer wiring in there, and you can pull it and take the harness for like $5 !
Old Jan 24, 2025 | 05:14 PM
mln01's Avatar
Why not just cut out the female connector and splice in a new Molex for whatever your project is?
Old Jan 24, 2025 | 06:54 PM
Frank4's Avatar
[QUOTE=mln01;921633]Why not just cut out the female connector and splice in a new Molex for whatever your project is?[/QUOTE
just prefer not to cut the connector off. If I can find the male end why would I? If I can find the male connector I can switch whatever I want to wire with a simple plug-in.
