Where do these pieces go....
I am in the middle of a a head gasket job, and I bought the kit for atlantic british with all gaskets i could ever want. The only thing is i can not figure out where these tube like gaskets go? When i broke down everything I did not see any of these gaskets. I also cant find them in the RAVE manual. When I took the heads to the machine shop they had no idea either. I hope the picture helps.
In a seperate issue, when I took off the valve covers I found these little brass rings...hard to discribe I will take pictures of them.
Yes, they go in the special drawer of left over parts...
Make sure you get them all out! They are the steel spacersthat keep the v/c gaskets from crushing. They will ruin your engine if they get stuck in the wrong spot. There are 4 on each gasket (side)
VikingDiesel
05-26-2009 02:43 PM
