Where do these pieces go....
Old Dec 18, 2011 | 06:44 PM
kmyer01's Avatar
Default Where do these pieces go....
I am in the middle of a a head gasket job, and I bought the kit for atlantic british with all gaskets i could ever want. The only thing is i can not figure out where these tube like gaskets go? When i broke down everything I did not see any of these gaskets. I also cant find them in the RAVE manual. When I took the heads to the machine shop they had no idea either. I hope the picture helps.
In a seperate issue, when I took off the valve covers I found these little brass rings...hard to discribe I will take pictures of them.
Old Dec 18, 2011 | 07:26 PM
That gasket kit covers many different engines, some parts are not needed.
Old Dec 18, 2011 | 07:32 PM
2001SE7's Avatar
Are any of the ones in question o-rings?
Old Dec 19, 2011 | 07:20 AM
kmyer01's Avatar
Yes, some of these are o-rings. I was thinking that some of these pieces might not be used, but was unsure.
Old Dec 19, 2011 | 08:53 AM
JEFIII's Avatar
The little brass rings that you are describing are most likely the original spacers/grommits that were in the valve cover gasket. Watch that they don't drop where you can't geth them. John
Old Dec 19, 2011 | 09:02 AM
threalassmikeg's Avatar
Yes, they go in the special drawer of left over parts...
Make sure you get them all out! They are the steel spacersthat keep the v/c gaskets from crushing. They will ruin your engine if they get stuck in the wrong spot. There are 4 on each gasket (side)
Old Dec 19, 2011 | 12:17 PM
jafir's Avatar
do the ones on the right look like this:
Land Rover Fuel System Parts | Fuel Injector "O" Ring (BOSCH Inject) 2 Per Injector
Old Dec 19, 2011 | 12:53 PM
2001SE7's Avatar
they might match up with the injector seals.
VikingDiesel
May 26, 2009 02:43 PM
Disco2Guy
Feb 22, 2008 12:36 AM
xtremehp13
Aug 23, 2007 10:44 AM
Slickblade365
LR2
Aug 15, 2007 01:17 PM
adowgiert
Sep 30, 2005 08:56 PM
