Where to find "Heavy Duty" Shuttle Valve
Old Jan 12, 2012 | 06:44 PM
Street Wolf's Avatar
Well, I just put a new battery in the truck (Needed one regardless of this problem) and no fix. Sits around 13.5-13.4ish with no headlamps or accessories on while driving down the road, and low to mid 12's with headlamps and accessories. Onto the next thing I suppose.
Old Jan 12, 2012 | 08:00 PM
Rovin4life's Avatar
actually if you read the current LR bulletin which has been out for about four years then you will notice the shuttle valve includes the module part of the abs modulator. takes an hour to change and bleed and fixes all the problems.
Old Jan 12, 2012 | 09:16 PM
jafir's Avatar
And I'm pretty sure that was the first link I posted:
Land Rover parts, spares, Land Rover accessories - Search results for SWO500040
Old Jan 13, 2012 | 08:51 AM
Better look for a replacement alternator cause your's isn't cutting it.
Old Jan 13, 2012 | 09:21 AM
Since this has pretty well turned into an alternator bash, it's perfectly fine.
Old Jan 13, 2012 | 10:43 AM
Who said we are bashing your alternator, facts are your voltage under load is way out of range for a D2. Low voltage will cause many different issues with any of the ECU's.
Old Jan 13, 2012 | 10:56 AM
I'm not worried about bashing of an alternator, it's not like I built it or really care about it. It is however not what is causing this issue, unfortunately seeing as that would make it an easy fix.
Old Jan 13, 2012 | 07:19 PM
ebg18t's Avatar
Spike555 posted a pic recently indicating the major grounds. Does anyone have that diagram? I want to check and clean my grounds tommorow.
Old Jan 14, 2012 | 05:36 PM
Well, I've got it where the voltage will stay in the 13's now with every light on at idle.
Old Jan 14, 2012 | 10:47 PM
ebg18t's Avatar
What did you do?
