Where to find an XYZ switch??
Old 05-21-2015 | 12:14 PM
cobbcj7's Avatar
Question Where to find an XYZ switch??
I have seen them on Ebay for around $100 and Autozone has them for $291.00... I can't really afford the $291.00 so is it safe to just get one on Ebay, or is there a different place that sells them used or cheap??
Thanks
Old 05-21-2015 | 12:18 PM
DustyLBottoms's Avatar
Thanks
About 6 months ago someone posted part numbers to cheap versions available at Advance or something.
Old 05-21-2015 | 12:25 PM
abran's Avatar
There is an article on AULRO that explains how to rebuild if you are really hurting.
Old 05-21-2015 | 12:26 PM
cobbcj7's Avatar
Is it possible to By-pass this switch??
I took it off the Disco, and cleaned it out completely.. It did not have any corrosive parts that looked too bad so I just put it back on and now the truck wont even start.. It will indicate that it's in park and neutral but nothing else shows on the Shifter or the dash indicating it is in any gear..
Old 05-21-2015 | 12:41 PM
cobbcj7's Avatar
I saw that page and used it as a guide.. But putting it back in is where I think the problem is.. not sure if it is lined up properly...
Old 05-21-2015 | 12:45 PM
drowssap's Avatar
go with a used one try paul grant
Old 05-21-2015 | 01:04 PM
acamato's Avatar
Here are the aftermarket part nos.
Wells LU408
AIRTEX 1S6524
CARQUEST 53-31848
STANDARD MOTOR PRODUCTS NS-476
BWD S41225
ROVER UHB100190
stu44mag
03-08-2023 11:45 AM
meltdowndave
11-05-2019 09:02 PM
meltdowndave
04-28-2019 09:53 AM
RicknCody
03-28-2010 07:49 PM
meltdowndave
09-26-2009 11:18 AM
Quick Reply: Where to find an XYZ switch??
