Where and how to mount my Hi Lift Jack
Roont (02-19-2024)
On my D1 I had back in the day I bought a set of PIAA light clamps that allowed me to mount the hi lift to the upper hoop on the OEM Land Rover brush guard. I honestly hate mounting a hi lift up high. First it's dangerous if it falls, or someone slips. Then they all eventually rust and you'll get rust stains on your paint. I mount them as low as I can get them or I throw it inside the vehicle.
So, I have a question about actually using the Hi-Jack. I have one and am petrified every time I need to use it. On my 01 I jam it into the front of the ARB, works fine. In the rear I jam it into the receiver on the hitch. Again, works fine. But in both locations I find the truck very unstable in the air.
Anyway, my question is, can you use one to lift a truck that does not have steel bumpers? I just realized there is no lift point on my 04's stock front bumper. I guess I'll just pick up a larger bottle Jack.
FYI. I'm lifted ~3.5" or so.
![](https://landroverforums.com/forum/attachments/discovery-ii-18/5415d1314887009-hi-lift-jack-mount-tire-dscf0001_2.jpg)
When I had it mounted on my front brush guard or ARB front bumper I had it bolted down. I DO NOT trust those quick release setups with something that heavy. Fine for the trail, but I'd hate to be in an accident and watch it fly thru the car in front of me. I used the largest Grade 8 bolts I could put thru it to secure it.
If I was parking somewhere over night that I didn't trust I'd wrap it with a cable lock. Rust wise I tried everything. WD40, the Hi Lift sleeve (UV Rays killed that 30.00 thing in less than a year....), and the last thing was spraying it down with a coat of clear coat from top to bottom. That worked until you used it and knocked the clear coat off.
caerb
02-26-2011 07:14 PM
JohnLRDisco04
09-21-2007 11:59 PM
